Do you need a convenient way to give your USB-C cable a little extra length or create a flexible connection? The Adapter USB-C male to USB-C female allows you to extend and adapt your existing cable for charging and data – practical at home, in the office and on the go.
The adapter requires no drivers – Plug & Play.
Simply connect your USB-C cable to the female port and plug the male connector into your device. The compact design makes it easy to carry anywhere.
Works with most USB-C devices and accessories (within the specifications of each product).
Typical uses:
Color: Black
Connection (A): USB-C male
Connection (B): USB-C female
1x Adapter
Report comment
Report sent
Your report cannot be sent
