• Apple Watch 5 (44mm) Nylon Armband - Flash
Nylon watchband Apple Watch 6 (44mm) - Flash
kr199.00
  • Made of durable nylon
  • Easy installation
  • Adjustable with Velcro
Nylon watch strap for Apple Watch 6 (44mm)
Soft and comfortable design
Nylon watch band for your Apple Watch 6 (44mm) is made of soft, airy and elastic nylon material that gives a comfortable feeling against your wrist. It is perfect for training and running but also for normal everyday use, such as at work, school or your leisure activities. The unique design provides a comfortable fit that adapts to your wrist and with the velcro buckle you can easily adjust the size of the watch bracelet to fit your wrist.
Security and stability
When you do all your everyday activities, you don't have to worry about your Apple Watch 6 (44mm) slipping off your wrist. With our Nylon watch strap, you can be sure that your watch is stable as the velcro buckle provides a secure grip and the watch strap's double layer of nylon material provides extra stability and durability.
Colorful choices
Nylon watch bands for your Apple Watch 6 (44mm) are available in a variety of colors so you can easily find one that matches your personal taste. Choose between simple and neutral colors for a classic look or go for a more eye-catching and outstanding look.
Specifications
Compatibility: Apple Watch 6 (44mm)
Material: Nylon
Attachment: 44mm
Contents
1x watch strap (smartwatch included not)
  • In stock
    20 Items
  • Basic Color
    Yellow
  • Device Type
    Replacement Watch Band
    Apple Watch 6 44mm
  • Compatible with model ID
    A2376, A2294
  • Attachment
    44mm
    Flash
  • Splash proof
  • Impact proof
    Nylon Watch Band
