This clear silicone case for the Apple iPhone 14 Plus provides premium protection without compromising the elegant design of your phone. This clear silicone case maintains the beautiful design of your Apple iPhone 14 Plus while protecting against everyday wear and tear.
Precision engineered transparent silicone case model-fitted for the Apple iPhone 14 Plus. The case improves your grip and ensures that your phone does not slip out of your hand during use. The case's transparency adds a subtle layer of protection that doesn't hide your phone's sleek look.
The transparent silicone shell provides minimal bulk and maintains the sleek and slim profile of your Apple iPhone 14 Plus. Enjoy the convenience of carrying your phone without the burden of a heavy or bulky case.
The phone case is made of high-quality silicone material and is flexible, durable and easy to install or remove. With this mobile case mounted on your Apple iPhone 14 Plus, you prevent daily wear and tear while the cover provides a comfortable grip for easy handling of the phone.
The case offers excellent protection against scratches, bumps and minor falls. This thin phone case is flexible, durable and easy to install or remove. Keep your Apple iPhone 14 Plus looking pristine and spotless to preserve your phone's appearance and resale value.
The case is designed with access to the phone's functions, giving you access to buttons, ports on your Apple iPhone 14 Plus. Maintain your phone's functionality while keeping it protected. This phone case is also compatible with wireless charging.
To clean the case, use mild soap and water, rinse well and allow to air dry. In this way, you keep the transparent silicone case clean from dirt and possible stains. In no time, your case will look as good as new, providing continuous protection and a clean look for your Apple iPhone 14 Plus. This washable design not only maintains the perfect condition of the case, but also contributes to better hygiene for your smartphone.
Colour: Apple iPhone 14 Plus
Material: Silicone
Contents
1x mobile phone case (phone not included)
Report comment
Report sent
Your report cannot be sent
