Clear Ring Case for Apple iPhone 14 Plus is a powerful cover with a slim design. It is made of a soft shockproof TPU frame with a hard PC material back that protects your phone from damage or scratches. The case has extra ridges around the camera and screen, so they won't get scratched on flat surfaces. The 4 corners of the case are reinforced with extra thick TPU material to protect your Apple iPhone 14 Plus against falls and bumps.
The transparent back of the Clear Ring Case for the Apple iPhone 14 Plus means that the phone's color and design can be seen through the cover. The hard PC material means that the shell is not scratched or otherwise damaged when you have it in your pocket, bag or lying on the table.
Clear Ring Case for Apple iPhone 14 Plus has a finger ring/selfie ring that can rotate 360 degrees. You can film, take photos and stream without worrying about dropping your phone. The ring can also be used as a stand, bode vertically and horizontally, so you can stream movies, music or browse photos without holding the phone in your hand.
On the finger ring/selfie ring, there is a metal plate that is compatible with the car's magnetic mobile phone holder. This means that your Apple iPhone 14 Plus sits stable during the drive so that you can easily see the phone's GPS function while driving without holding it in your hand so that you can drive safely.
Specifications
Color: Silver
Material shell: TPU (Thermoplastic Urethane) + PC
Contents
1x mobile case (phone not included)
Report comment
Report sent
Your report cannot be sent
