The USB-C connector allows you to charge your Garmin Epix Pro (47mm) with a wide range of power sources, including wall chargers, power banks and computers, giving you flexibility and convenience. By choosing the 4-pin USB-C data sync and charge cable for your Garmin Epix Pro (47mm), you get a reliable, efficient and user-friendly charging and data transfer solution that enhances your overall experience.
Simply connect the 4-pin connector to your Garmin Epix Pro (47mm) and the USB-C connector allows you to charge your Garmin Epix Pro (47mm) with a wide range of power sources, including wall chargers, power banks and computers, giving you flexibility and convenience.
The charging cable transfers data at high speed, allowing for quick updates and efficient synchronization of your data, saving time and ensuring your Garmin Epix Pro (47mm) is always up to date.
Specifications
Connector from: USB-C
Connector to: 4-pin
Color. Black
Length: 1 meter
Compatibility: Garmin Epix Pro (47mm)
Contents
Report comment
Report sent
Your report cannot be sent
