• Charging Cable Ladekabel Data-Sync 90° USB-C Garmin Fenix 5X Plus
kr239.00
  • 90 degree
  • Supports fast charging technology
  • Braided aluminum cable
Versatile charging options
The 90° USB-C connector allows you to charge your Garmin Fenix 5X Plus with a wide range of power sources, including wall chargers, power banks and computers, giving you flexibility and convenience. By choosing the 4-pin 90° USB-C data sync and charge cable for your Garmin Fenix 5X Plus, you get a reliable, efficient and user-friendly charging and data transfer solution that enhances your overall experience.
Flexible and portable
Easy to use
Simply connect the 4-pin connector to your Garmin Fenix 5X Plus and the 90° USB-C connector allows you to charge your Garmin Fenix 5X Plus with a wide range of power sources, including wall chargers, power banks and computers, giving you flexibility and convenience.
Fast and efficient
The charging cable transfers data at high speed, allowing for quick updates and efficient synchronization of your data, saving time and ensuring your Garmin Fenix 5X Plus is always up to date.
Specifications
Product: Braided aluminum cable
Connector from: 90° USB-C
Connector to: 4-pin
Color. Black
Length: 1 meter
Compatibility: Garmin Fenix 5X Plus
Contents
  • In stock
    50 Items
  • Basic Color
    Black
    4-PIN
    Charge cable
    Aluminum Alloy
    Black
  • Interface
    USB-C
    1x charging cable (watch not included)
    Charge cable 90 USB-C
  • Längd (m)
  • WEEE 2.2 (kg)
    0,020
