A smart solution to protect your Motorola Edge 50 Pro camera lens with a thin tempered glass protector.. Double adhesive underside for easy installation. This camera protector is made of 9H hardness-enhanced tempered glass that maintains perfect image sharpness while protecting your phone's entire camera surface from scratches and external impacts. Tempered laminated glass keeps your Motorola Edge 50 Pro camera lens glass shatterproof. The lamination holds the glass together should it break. As this is a glass camera protector and not a film, it does not bubble upon application.
Motorola Edge 50 Pro camera protection in tempered glass provides optimal clarity. The oil-resistant oleophobic coating reduces dirt, scratches and fingerprints. Enjoy optimal sharpness for your camera lens and easy cleaning to maintain a clean camera. Although the glass offers good camera protection for your Motorola Edge 50 Pro, the glass is incredibly thin. The thin camera glass is designed to protect the camera while maintaining the appearance of your phone. Protect your phone's camera from damage in a cost-effective way.
Compatibility: Motorola Edge 50 Pro
Material: Tempered glass 9H
Thickness: 0.2mm
Report comment
Report sent
Your report cannot be sent
