• Garmin Forerunner 245/245M Charging Cable Data-Sync
Charging Cable Data-Sync Garmin Forerunner 45 Plus
kr189.00
  • Easy to use
  • Supports fast charging technology
  • Small and compact
Versatile charging options
The USB-A connector allows you to charge your Garmin Forerunner 45 Plus with a wide range of power sources, including wall chargers, power banks and computers, giving you flexibility and convenience. By choosing the 4-pin USB-A data sync and charge cable for your Garmin Forerunner 45 Plus, you get a reliable, efficient and user-friendly charging and data transfer solution that enhances your overall experience.
Flexible and portable
Easy to use
Simply connect the 4-pin connector to your Garmin Forerunner 45 Plus and the USB-A connector allows you to charge your Garmin Forerunner 45 Plus with a wide range of power sources, including wall chargers, power banks and computers, giving you flexibility and convenience.
Fast and efficient
The charging cable transfers data at high speed, allowing for quick updates and efficient synchronization of your data, saving time and ensuring your Garmin Forerunner 45 Plus is always up to date.
Specifications
Connector from: USB A
Connector to: 4-pin
Color. Black
Length: 1 meter
Compatibility: Garmin Forerunner 45 Plus
Contents
  • In stock
    100 Items
  • Basic Color
    Black
    4-PIN
    Charge cable
    TPE
    Black
    1x charging cable (watch not included)
    Charge cable Data-Sync
  • Längd (m)
  • WEEE 2.2 (kg)
    0,015
