• Garmin Forerunner 45 Plus Charging Cable Data-Sync
USB-C Adapter Garmin Forerunner 45 Plus
kr99.00
  • Easy to use
  • Supports fast charging technology
  • Small and compact
USB-C Adapter for Garmin Forerunner 45 Plus
USB Type-C female to 4-pin charging connector, specially designed for Garmin Forerunner 45 Plus. This handy and compact adapter allows you to charge your Garmin Forerunner 45 Plus with any USB Type C cable, making it a convenient and versatile accessory.
  • Tailored Compatibility: This charging adapter is exclusively designed for the Garmin Forerunner 45 Plus, ensuring a perfect fit and seamless charging experience for your premium sports watch.
  • USB Type C connection: Take advantage of your existing USB Type C cables to charge your Garmin Forerunner 45 Plus, eliminating the need for a separate charging cable and simplifying your charging routine.
  • Easy to use: Simply connect the 4-pin end to your Garmin Forerunner 45 Plus and the USB Type C end to a compatible cable, and you're ready to charge your watch with ease.
  • Compact and portable: The slim, lightweight design makes this charging converter convenient to carry in your pocket, purse or attach to the integrated loop, ensuring your Garmin Forerunner 45 Plus is always ready for action.
  • Durable Design: Constructed with high-quality materials, this charging adapter is built to withstand daily wear and tear and provides a long-lasting charging solution for your Garmin Forerunner 45 Plus.
  • Fast charging: The USB Type-C adapter supports fast charging capabilities, allowing you to quickly charge your Garmin Forerunner 45 Plus.
Upgrade your charging experience with the USB Type C Adapter for Garmin Forerunner 45 Plus. This handy adapter makes it easy to charge your smartwatch using the same cable as your other devices, offering convenience and versatility.
Specifications
Product: Charging adapter USB-C
Connect from: Type C female
Connector to: 4-pin male
Color. Black
Compatibility: Garmin Forerunner 45 Plus.
Contents
1x Adapter (clock not included)
  • In stock
    100 Items
  • Basic Color
    Black
    4-PIN
    Adapter
    Polycarbonate
  • Wrist strap hole
    Black
    USB-C Adapter
  • WEEE 3.4 (kg)
    0,004
  • PPWD CB (kg)
    0,015
