Slim Ring Case for Apple iPhone 14 Plus is a powerful cover with a slim design. It is made of soft shockproof TPU material that protects your phone from being damaged in the event of a fall or impact. The case has extra ridges around the camera and screen, so they won't get scratched on flat surfaces. The inside of the shell is equipped with a special heat dissipation technology so that the mobile phone stays cool when you stream, play or surf.
Slim Ring Case has a modern design and style that is both elegant and functional and provides complete protection for your Apple iPhone 14 Plus. It is thin, light and soft so it sits slim on your mobile phone so you hardly notice it is on. The case is designed to provide easy access to all the phone's ports and buttons, so you can use your mobile phone without having to remove the case. It also has perfectly cut holes for the camera and other important features, ensuring that your mobile phone works properly while in the case.
Slim Ring Case for Apple iPhone 14 Plus has a finger ring/selfie ring that can rotate 360 degrees. You can film, take photos and stream without worrying about dropping your phone. The ring can also be used as a stand, bode vertically and horizontally, so you can stream movies, music or browse photos without holding the phone in your hand.
On the finger ring/selfie ring there is a metal plate that is compatible with the car's magnetic mobile holder. This means that your Apple iPhone 14 Plus sits stable during the drive so that you can easily see the phone's GPS function while driving without holding it in your hand so that you can drive safely.
Specifications
Colour: Black
Material shell: TPU (Thermoplastic Urethane)
Contents
1x mobile phone case (phone included not)
Report comment
Report sent
Your report cannot be sent
